Displays various BOOTP Relay configuration details.
| ipv4 | Specifies unconfiguring the DHCPv4 BOOTP Relay service (default). |
| ipv6 | Specifies unconfiguring the DHCPv6 BOOTP Relay service. |
| vlan | Unconfigures BOOTP relay for a specified VLAN. |
| vlan_name | Specifies the VLAN name. |
| include-secondary | Removes the include-secondary configuration for the specified VLAN. |
N/A.
Use this command to display BOOTP Relay details for IPv6.
The following command :
# show bootprelay configuration ipv6
DHCPv6 BOOTP Relay : Enabled on virtual router "VR-Default"
Include Secondary : Enabled (parallel)
VLAN DHCPv6 BOOTP Relay
VLAN "Default":
BOOTP Relay : Disabled
VLAN "v1":
Include Secondary : Enabled (sequential)
VLAN "v2":
DHCPv6 BOOTP Relay : Disabled on virtual router "VR-Default", but enabled on some VLANs.
Include Secondary : Disabled
VLAN "Default":
This command was first available in ExtremeXOS 15.4.
Information about DHCP/BOOTP relay being disabled for the VR, but enabled on some VLANs was added in ExtremeXOS 22.5.
